the best way to replace the shock on a 2012
who knows the easyest way to replace the subframe on a 2012 . i have replace the shock spring and to do this i puth of the compl. subframe with filterbox and booth .to install this, afther 15 min traying to get the booth over the fi housing with no succes i take off the filterbox with the boot from the alu subrame and first puth the booth with airfilterbox on the fi and than set back the alu sub frame . as they told in the manual you most puth it back together buth there is so little room to get the booth over the fi housing , for me no succes this way .
Remove muffler
remove lower and upper shock bolts
remove all subframe bolts, but leave on, and don't loosen throttle body clamp
push subframe to the side and slide shock up and out.
Just do the opposite if you are trying to install an airboot. Do it with shock out, and put shock in later.
