Change chain guide, slider, roller when chain change?
Hi
I'm going to change my sprockets and chain, should I then also change the chain guide, chain slider and the 2 chain rollers?
(Can upload pictures if necessary)
Thanks - The dane :busted:
Good question. Those are items that get over looked.
It is not mandatory. You really just want to make sure that the bearing in the roller is in good working order, that the chain slide is not cracked and that all the bolts and spacers are in tact and that the chain guide is not completely worn out.
TM Designs makes some great replacement pieces when you are ready.
