XR400 Shim Stack Mod
Hi All.
Been reading about this mod, does it work for all years of XR400, mine is a 2002?
Also where are the shims located, I know they are in the bottom of the fork, but which bit?
Thanks
It should work for all XR400's. You will need to completely disassemble your forks. I believe it is the compression shim stack that is fixed to the bottom of your fork. If I remember there are 12 shims and I removed 6 of them. When you completely tear down your forks it will unscrew from the bottom of your fork.
