Screw that clutch switch!
I've been having increasing difficulty starting the bike where it wouldn't start unless the clutch was in a very specific position, turns out the clutch switch was going. Threw screws later...I ripped that sucker out.
Do I need to cap off the plug that the switch sat in on the clutch lever, or can I just leave it open? Thanks!
Guess you should connect the two wire together ?
Shold be easy to sort out anyway..
Sorry, I meant the hole that the sensor plugs into on the clutch lever, not the wires in the wiring bundle (already connected those together).
yes , cap it off .. for neatness
How do you cap it off???? Im assuming you mean the perch.
