Throttle Cable Adjustment on FI KX 450
My manual doesn't explain how to correctly adjust the push pull throttle cables on my KX 450. I've adjusted free play by messing with both adjusters, but really want to know how each of the two cables should be adjusted. Would appreciate help from anyone that knows the correct procedure!
Adjust the pull till there is .5mm of play (or less, which I prefer). Then adjust the push cable till there is no slack plus 1/8 of a turn.
