Flasher help, electrical troubleshooting
I got my BB put back together and went for initial ride yesterday when I found that my left front turn signal flashed really fast and the left rear didn't flash at all, which has me thinking the power to the rear might be pinched and its all going to the front. Anyone had this before or know where I should start? I really don't want to take everything back apart already if I can find the spot quickly. Thanks for any tips!:busted:
No tips. The fast flash is because the rear is not working. Maybe the rear bulb. Check for power and ground ground at the rear. If no problems at the rear, work forward until you find a bad connection or broken wire.
