Valve Spring Pressures
The spring pressures from Kibble white and R/D are off in terms of installed height pressure and at lift pressure between them. The R/D springs compare to Ferrea in terms of spring pressure.
What spring pressure(s) are valid for radical cams with high lift short duration?
The Kibble White valves have lost a TON of installed height seat pressure. The full lift pressure is larger than the RD or ferrea.
What is the minimum safe operating installed pressure and full lift pressure @ 11,200RPM?
KIBBLE WHITE
Installed Height
Exhaust 1.360-1.370 72#, .375 184#
INTAKE 1.275-1.285 40#, .375 130#
BASE Thickness
Intake
Exhaust
LEFT EXHAUST RIGHT
LBS LIFT LBS
56 1.36 56
166.5 -0.375 161
175 -0.4 173
LEFT INTAKE RIGHT
LBS LIFT LBS
25 1.36 27
111 -0.375 116.5
116.5 -0.4 122
SPRING ERROR %
LEFT RIGHT
28.57142857 EXHAUST 28.57142857
10.51051051 14.28571429
LEFT RIGHT
60 INTAKE 48.14814815
17.11711712 11.58798283
R/D SPRINGS 1085 Springs
Installed Height
Exhaust 1.250 - 1.270 60#@1.250, 125#@-.400
INTAKE 1.310 - 1.330 53#@1.310, 117#@-.400
BASE Thickness
Intake 0.11
Exhaust 0.247
EXHAUST
LEFT DIFFERENCE %
55 60 9.0909091
107 125 16.8224299
RIGHT DIFFERENCE %
55 60 9.0909091
110 125 13.6363636
INTAKE .800 coil bind
LEFT DIFFERENCE %
52 53 1.9230769
110 117 6.3636364
RIGHT DIFFERENCE %
45 53 17.7777778
110 117 6.3636364
Even if you knew the answer to that question, how could you (the common man, without LVDT's Strain Gauges Etc..) dynamically check it?
They give you static dimensions. :busted: :busted:
The KW's are nearly 50% stiffer at .375. After being used 10 hours the KW's checked out to be:
Exhaust
56# installed
166# -.375
Intake
25# installed
116#@ -.375
R/D
As checked:
Exhaust
55# installed
110# -.400
Intake
52# installed
110#@ -.400
This is just a static test to see what the spring rates are compared to new. In comparing these numbers the pressures are significantly different between manufacturers.
This brings the question: "what is the minimum pressure needed to keep the valve train from floating a valve?"
To answer the question, the same as it is when the engine is at rest...it doesn't change.
I think your question is really "why do the KW have such high seat pressures and over the nose pressures?"
The answer to that is, the stock springs are just barely adequate brand new on a Ti valve. The stainless KW valve is quite a bit heavier and needs more spring to follow the cam at the same RPM. Since its a straight rate spring, the pressure will continue to rise as it is forced over the nose of the cam. Regarding your probable primary concern, you wont wear out the cam or followers with the heavier springs.
If the KW have decreased in psi/inch there is a point where the springs cannot do their job. At what loss in pressure is there concern? When comparing 3 sets of springs only 2 have the same spring rate when new.
In trying to compare the Ferrea and R/D the spring pressure is less than the KW's new.
I don't have a set of Ferrea valves to weigh so I am excluding the weight difference from KW to Ferrea. However, the R/D springs are HD springs for stainless. Since they are about the same spring rate as Ferrea, I imagine the 450 head needs no more than the psi they give.
The KW springs may have a work loss built into the spring rate when new. How much pressure isnt really the issue with these heads as much as the resonance that sets in on some springs. Notice, none of them have dampers...If the things start bouncing you end up with valve float when you're not even revved up very high.
