All my gear oil in Motor oil?
I did just recently do a crankshaft and seals. I am having a hard time visualizing if there is any other possible way it could have happened. SUKKS
Like William said, right crank seal. The balance shaft seal will also let the oil transfer to the other side. Regardless of whether you just replaced them, one of those to seals are bad and causing your problem.
