e start Missing shim/tophat/collar for bendix.
I replaced my bendix but I must've lost a shim or a tophat/collar because the bendix is flopping around even with the cover bolted on. I have the tophat that goes in the cover but I'm missing something from the case. The hole in the case is much bigger then the end of the bendix. I can't find it on the parts fische either. Anyone?
I don't think there is anything in there and the case hole wears out quickly because of it. On my 08 I used a case cover dowel and ground it shorter and epoxied into case. Never a problem again.
There are 2 tophat/dowels one on each side of the bendix, they are under "ignition system" in the parts fische and only show up in the 2010+ models with e start in the fische. #19 in the fische:
Nope I'm missing these 2 little spacers:
Can't find them online, luckily my local KTM shop has them in stock.
