2000 ttr 225 no spark
I have been riding it with no problems and it just died. Hit the start button and it would fire and imedatly die. Changed the plug and had same results. Checked the spark plug when turning it over and it will spark once or sometime two times and not spark anymore. I have checked all electrical connections and found nothing wrong.
I hate to buy a new coil or CDI box and that not be the problem. Is there any way to check these?
Any sugestions
I have the same problem.. so my cousin swapped his coil.. rectifier ..and cdi from his 225 and nuthing.. now both bikes have the problem like the flew.. please if you find out let me know and I will so same
if you need a cdi, pm me.
sounds like the stator is pooched from your description. the testing procedure is in the Yamaha TTR shop manual, if you don't have one its a good investment.
When my TTR had the same symptom, it turned out to be the stator.
