pds shock bleed procedure
If I put a bladder in my 06 ktm shock, is the assembly and bleed procedure basically the same as a newer kyb shock? Do I use the top bolt, or the compression adjuster to do the final bleed.
If I choose to stay with the piston, how is the final bleed accomplished?
thanks guys
