HANDLING PROBLEMS Conversion Chart
It tells you what direction to go when adjusting your suspension based on the different feelings and reactions your bike makes when riding. I carry this in my camel pack when I ride and never take it out. Hope this will help some of you dial your bike in a little better.
HANDLING PROBLEMS
Jarring => harsh ride in the handlebars on relatively small but sharp bumps
Decrease compression and rebound so wheel comes up and goes down faster
Try a fork spring with a lower spring rate for a softer ride
Packing => harsh ride in handlebars on larger bumps
Increase compression in the forks to limit the compression
Decrease rebound to help the wheel return more quickly
Try stiffer fork springs
Headshake => front wheel oscillates side to side, especially in soft stuff
Move forks lower in triple clamps to increase rake and straight-line stability
Decrease rebound in forks so wheel rolls over rather than ploughs into ground
Try stiffer front springs and softer rear spring to move center of gravity rearward
Over- steers => bike turns too quickly, goes inside the turn, front wheel knifes
Move forks lower in the triple clamps to increase rake, slow down turning
Decrease rebound on both forks to slow down the turning
Install stiffer fork spring so wheel won’t sink in and bite too much
Under-steers => bike turns too slowly, drifts wide -- front wheel pushes, washes out
Move forks higher in triple clamps to decrease rake and speed up turning
Increase rebound on both forks to increase “cone effect” and speed up turning
Bleed air pressure in both forks to stop the front wheel from pushing
Try softer fork springs so wheel bites rather than pushes the ground
Kick-up => rear wheel hops straight up, seat pops you in the butt
Increase rebound to slow down wheel’s return after hitting a bump
Swapping => rear wheel hops side to side in hard to loamy whoops
Increase compression, and/or decrease rebound to eliminate packing
Braking Hop => rear wheel hops excessively when braking for bumps or a corner
Decrease shock’s rebound to help wheel follow the bumps more quickly
Acceleration Hop => rear wheel hops badly on rough ground during acceleration
Decrease rebound to help wheel follow the bumps more quickly
If that doesn’t lessen the kick-up, decrease the shock’s compression
Acceleration Spin => the rear wheel loses traction under heavy acceleration
Increase rebound to improve rear wheel “squat”
That's a very very general idea. Maybe as a novice suspension setup but when it become more advanced there are way more things to take into consideration.
Exactly! It's a general idea of what to do for us suspension beginners, this isn't for the advanced. Yes, we know there's a lot more based on what all the experts say on this fourm, but for those of us that just ride and race for the love of it and would like a general idea of some basic trouble shooting, I think it helps. It has defiantly helped me out. I got rid of that annoying rear wheel hop and front tire washout, which was hurting my riding!
