Parris crank mod
I know this has been discussed before,and all the pros an cons why it wont/will work, but,has anyone ever actually rode or seen a bike with this mod sense it has been around for a while now?
Is this the one with the swirl marks for "turbine" effect cut into the crank wheels?
If so, I read a test several years back that showed ZERO conclusive gains/losses from this mod.
The theory and idea would actually work had the machine the crank the entire gap between the small lines they did.
for it to actually move a significant amount of air it would need more displacement than the small grooves they do. It basically would "calvitate", or just have a small barrier of dead air it was cutting through as it spins.
If it were machined in a way that actually had "paddles" with sizable gaps to catch and push the air, it should add significant increase in power.
On there web page the power gain they state is at a different elivation. If your going to state a power gain do it on the same dyno in close to the same conditions.
