87 xr100 smoking issues
Ok so i have an 87 xr100r and when i got it it had some issues as follows
- timing was off 2 teeth - fixed that
- helicoil for spark plug tube - fixed that
- no compression - removed head and shard of metal had odstructed intake valve from closing off all the way - fixed that and relapped both intake and exhaust valves and they now fit and close off perfectly, but only the exhaust valve has a seal and the intake seat cone is not fitted for a seal and i also removed the piston and rings look new and cylinder had recently been honed - i bought this bike from a guy that i think tried to work and could not get it to run due to timing being off and no keyway so i fixed that too. Anyway my question is the bike smokes like a 2 stroke and i am wondering why the intake valve has no seat and could that be my smoking problem????? The top end kit came with 2 valve seals and i put 1 on the intake but it streches the seal (badly) and the cone is tapered and i thought the seal could slide off and obstruct valve opening or closing so i removed it before reinstalling the valve spring and now it smokes like a 2 stroke - all the online microphish i have found only shows a valve seal for the intake and not the exhaust so why is my bike backwards?????????? I am trying to get this bike running well so i can tear it down and basically restore it for my son for christmas. Any help would be appriciated. Pardon my spelling errors.
I seam to remember the early XRs had only one valve seal and later years they switched to two? I would still replace the rings either way as they're only a few bucks for piece of mind while it's apart.
You should scroll down and look/search the XR100 forum for better results, as there are some guys there that know that engine very well.
