Warp 9 wheel fitment issue
I went to go put my new warp 9 18 inch rear wheel on my 2008 Rm 250 tonight and i moved the wheel spacers over from the stock 19 inch wheel but when i installed the wheel there was a massive gap and the entire wheel was wigling around. Do you think the wheel is the wrong one or that i need larger spacers?
Sounds like they sent you the wrong one. The hubs should be the same, it's the rim that is different and the stock spacers should fit. You could make a custom set of spacers, but you would need to make a new set each time they wear out. I would return it and get the correct one.
