kx 134
Some advice needed please. I have a kx 125 and its been oversized by 2mm by using a ktm 144 piston. On inspection of the rod that is 1mm longer than a standard one. Also the big end is 2mm larger diamiter than the standard kx and it dose not have any info printed onit so i am strugling to find a replacement. dose any body know why the big end would be made 2mm bigger. thanks dan.
Edited by daniel roberts
bad title
any markings on the cylinder as to whom might have done the work. most shops or persons will engrave their name or business intials on the cylinder.
