how to remove the Jet Needle? (the throtte cable is in way)
i still can't figure out how can the Jet Needle comes out, with that surprisingly stiff spring and throttle cable in the way. How you guys do it? (not talking about the main jet or pilot jet in the bottom of the carb, but the "top" part)
You just pull the spring with your fingers away from the needle and while holding it push the cable towards the needle and you will see a cut on a needle screw,then move the cable out through that cut. When you do that yust unscrew needle out
thanks Hepening! got it off!
now by any chance you know what size is the bolt inside that's holding the nieedle?
No problem :busted:
