Oil from ignition
Hey i am in need of some noob help!!!!!!
Been searching all over and cant find aswers. This is my first go with this kind of bike. Just put to gether a 1998 KTM 620sc.
THE GOOD: Bought from a friend. Motor has been rebuilt and in shrink wrap for 4 years.
THE BAD?: Bike is running now. 45min on motor. Oil dripping from dain hose on bottom of stator housing.
It looks to me like it should be a dry ignition but i dont know. And if it is, does anyone know if the seal there can be replaced from the outside or if you have to split the case. Any knowledge would be great thanx
I found the info i needed. Should be dry. I have a bad crank seal ring. can be removed and replaced from out side.
