Stock rear spring rates 250/400?
Anyone know the stock spring rates for both bikes? XR250R/XR400R?
I have a 95 250 and am getting a 96 400, wondering if the 400 will be stiffer. The 250 is a bit soft for me @ 225lbs.
Thanks!
400 is a 9.8 or 10kg rate. I've seen it listed both ways.
Thats not gonna give you the full story though. The 400 has a Showa shock and the 250 has a KYB so I'm not sure how well they will compare if you just look at spring rates.
@ 225, you might have to go 1 or 2 rates stiffer on the 400.
Your bike comes stock with a 9.3 shock spring according to the racetech calculator. It shows a 9.8, 10.3, and a 10.7 available for replacements, at 225 you would be in the 10.3 range or heavier.
http://racetech.com/ProductSearch/1/Honda/XR250R/1995
I'm 220 and the 9.8 stock spring on my XR 400 suits me just fine, the front end is soft though
