kdx220 tear down
Hey guys. Im a long time lurker and I finally joined.
Im tearing my 1997 kdx 220 down to rebuild and have hit two walls :busted::banghead:
I need to buy a flywheel puller and I need to know what size.
Secondly on the crank I need to know the thread direction and the best way to hold the gear on the crank to break the nut loose.
Thanks alot.
A catalog like Dennis kirk or Rocky MTN ATV should tell you what puller you will need.
Should be a right hand thread on the nut.
There is a source for manuals on the kdxrider.net forum. Order online and print it out.
27mm x 1.0mm, left handed threads
Be sure to grease the threads and the end of the crankshaft. If it is threaded on the end, put a socket head bolt in the end and let it turn on that and not the end of the crankshaft. (greased)
I have used a penny between the gears during breaking the nut loose, before I bought a gear holder.
