what needle
I have a 06x with a 2005 r cam, 07r head, 08r piston, airbox open and defuser removed. I don't want to start all over on jetting but it has a jd needle (i think) no numbers on it. I want to try a cfr250r needle but dont know if to try a 07 needle because of the 07r head or a 08r needle because of the 08 piston and my jetting is kinda of close to the o8r. I have a 55 leak same as a 08, 185 main, 08r 188 so i'm thinking of the 08 needle, can anyone tell me the number of needle and clip position.
I am thinking that the 05R needle should be best. Reason being is if you are using your X carb it is 37MM. The 04-05 R's used the 37 also, 06-09 use a 40MM carb which would change the air flow characteristics thus changing fuel requirements.
that is a good point what position was the clip. The reason i was think about the 08 was because most of my jetting was close to it and the 08 had a 55 leeak jet and i didn't want to take the carb all the way off again, that gets to be a pain after a few times. I may keep the one i have because it runs darn good. When warm just touch the start botton and the motor doesn't even sound like it spins just comes to life and there is no bogging at all just thought i may could squeze alittle more out of it.
185 or 188 main way too big, even with the jd needle. Forget the R specs unless you have an R, and even with the R's they usually run better jetted down from stock.
it has all r parts except carb., i start lean and had alot of bogging. Kept going bigger and bigger on the main and would go bigger if i had one. It ran better everytime i went richer. Now i can't make it bog, after warm up. The motor sounds so much better rich, makes me believe alot of people are running leaner than they think they are. If anybody is having bogging problems try going up on the main, like in the 180's just to see if it helps. A leak jet only helps for a few seconds, a main jet is continous.
Its sucking air somewhere
You really need to look at the back boot on the carb to the airbox. It is really easy to overlook a air leak because it is hard to see all the way around to make sure the boot is not folded over and is secure. Main jets in the 180's just doesn't sound right??
before i started i spayed carb. cleaner all over both boots and could not find anything. But I didn't check the valve clearance, the intake maybe out, I need to check the valves. I just had seen the jetting for a 08 and a 09 crf250r with a 188 main but larger leak, so i didn't think too much about the 185 main i had in it and it may have alittle more hit with a leaner main but the larger one sure pull good out of the hole in 3rd and up. First and second i can wheelie just by twisting the throttle and no clutch. Absolutele no bog and a good deep exhaut note without the defuser.
  • Similar Content
    • By Connor Wright
      Hey I have a crf250x 2005 I was riding today in top gear flat out and when I slowed down blue smoke just poured out the exsaughst then I happened to open the air box lid and saw it has what looked like engine oil in it then took out air filter and noticed that there was splatters of engine oil on the inside and that and the channel that goes to the carby had engine oil all over it.
      Also bike got a top end rebuild 15 hours ago
      The engine still runs good and sounds normal
      why would this be happening on a resonabley fresh engine
    • By mikemcbride
      Hey everybody. Quick question for y'all. I recently went riding and about halfway through my ride my motor seized on my '07 CRF250X. I haven't investigated it much but I checked the oil when I got home and there basically was none so I'm assuming that was the culprit. There weren't any metal shavings in the filter or on the plug either. At this point I'm trying to decide to rebuild the motor or just sell the bike as is and let the next buyer deal with it (they would know the deal obviously.) I feel that I'm pretty mechanically inclined but rebuilding a CRF engine is a bit out of my league and I assume paying a shop to do it would put me out more money than the bike is worth. So, I have this question to ask; what would be a fair price for a pretty dang nice shape 07 CRF250X, with a seized motor with an unknown extent of internal damage?
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By TerryA
      I have two rides in on my new Rekluse auto clutch and I have to say I'm very pleased. The install wasn't hard, but was pretty much a all afternoon sort of project. I also installed a left hand rear brake kit and a two finger cluth over-ride with the adjuster on the perch (which I rarely seem to need). It has all worked great right from the beginning. After struggling to get up a tricky hill in first gear, I tried it in second and the autoclutch helped me clean the hill easily. Not having to worry about clutch action in techinical sessions has also eased fatigue and just made it more fun all the way around. I ride mountain bikes alot, and having both brakes up on the bars has also been nice as it makes for a set-up just like the bicycle - in fact I like that as much as not having to worry about clutch manipulation. The brake on the bar is especially nice on tricky downhill sections where you need to paddle, such as nasty rock/rut stuff. So first impressions are that it was worth the investment -making the ride more enjoyable and easier at the same time!
    • By Mikey560
      I was driving the bike for 15min or so and all of the sudden the bike stalled. I tried starting it again with no luck. I took the spark plug out to see if there is spark so i ground the spark plug to the frame and there is no spark. I even put a new spark plug in the bike and still nothing. Any ideas what i should check??
