2003 Warrior 350 electrical problem
I have a 2003 Warrior and I'm struggling with an electrical problem. The bike starts and runs great, but it cuts out when I attempt to put in in reverse. It seems as soon as the red reverse light comes on, it cuts the ignition somehow. I tried to troubleshoot the problem and discovered it won't crank the starter if the bike is in gear when I pull in the clutch. It will only crank over in neutral. I went through the electrical diagram, but I'm not very skilled with the electrical stuff. Can someone point me in the right direction to troubleshoot and hopefully fix this problem? Thanks a lot for your help!
