I need a reapair manual for a 2007 450/505 sxf
Does anyone have a pdf file or know where I can get this manual? I'm trying to install new cams on my bike and want to make sure I do it right....Thanx so much!!
They can be ordered from any dealer / online
E-Bay...There's lots of them there.
I am in process of top end rebuild. A couple of things... KTM says you need to check radial clearance of camshaft bearing with their plastigauge. It will take forever to get it thru KTM and cost $20+. Plastigauge is actualy a brand name and you can get it from any parts store for $2. You want the green one (smallest).
the engine needs to be at TDC with cam lobes facing outward. There are holes on the lobes and those line up parallel to top of head. The holes are about 3/8" diameter and it is unclear if the top or bottom of the hole should line up with top of head. Looks to me like bottom of hole lined up to edge of head is the right spot. You need to press off/on the timing gear on the cam aswell. definitely check your valve lash when done.
spark plug removal is a royal PITA without special tool. I took a spare socket (16mm...I THINK...) and kept working it on bench grinder until I could wiggle it into the hole, then the perfect length socket extension, or you can't fit ratchet under frame.
and when the valve cover bolts back onto the cam bridges.... careful. those cam bridge holes strip super easy. I believe cam bridges are line bored with head... whaetver it is...you can't replace cam bridges, you have to replace complete head. I went to local machine shop and he heli-coiled my srtipped cam bridge.
good luck and I hope it is smoother for you, than it's been for me.
thankyou very much for the advice. I'm going to try the cd route to be sure, also I would like all the tech info such as torques ect... You guys are great
dez, I can help you with pdf. PM me. save yourself some $$, cuz KTM will gladly take it from you when you start buying parts.
??? Shouldn't the cams just go right back in? What do you mean by this? Guess i'm missing something...
  • Similar Content
    • By element9
      The story begins with simple installation procedure of a BIG BORE kit that we ordered from USA . The manufacturer (CYLINDER WORKS) and the dealer send us the correct kit and so far so good ! .
      The bike is a KTM 250 sx-f ,2011 model and bellow there are some photos for you, just to see how careful I am throughout the process .
      .. .. .. .. I change the valve seals and the exhaust titanium valves and springs with the PROX steel kit and make a little polishing on the intake and exhaust
      Put the cylinder-piston on and always with guidance from workshop manual and correct clamps...
      Until now we where happy !!! We start the engine ,and everything seems to be ok!
      Began to make the first ride and…… DISASTER !!!
      The engine start bleeding OIL from the hose-tube !!!!!!!!! I thought its normal if it is one-two drops but unfortunately didn’t STOP .
      We did one more ride to see what happens and still BLEEDING. Back to the WORKSHOP.
    • By Dutch84
      I got about 6 months on my 350 xcf-w. I ride a lot of tight, rocky,rutty, slippery single track in South west PA. The only things I've added are suspension, bark busters, skid plate and disc protectors. I purchased a trail tech mapping switch but hesitant to add it as I heard the dealer needs to unlock the ECU and am not sure how much of a benefit it will be. I have a Scott steering dampner I'm going to add. I'm also looking at exhaust options for my riding conditions. What do you guys think about the items listed and what suggestions do you have?
    • By OffroadMT
      I am purchasing a 2012 KTM 350XCF after wanting one for a year and finally picking one up in December. My question is what are some good things to watch for on this bike as far as initial set up and good Mods to improve bike ? My plan is to add a skid plate, hand guards and muffler with the possibillity of changing the header pipe and a Rekluse EXP would be nice as we ride mostly single track mountain trails with some rocks . Any good thoughts and suggestions would be appretiated
    • By shift1313
      Hey guys, i just picked up a used 2012 ktm 450 sxf to be my supermoto race bike next year. the bike seems pretty much stock but there is a connector on the left side of the steering stem that I am 99% sure couldnt be factory. Its a 4 pin connector, 2 wires in, 2 wires out(to the Estart switch on the bar). On the estart side of the connector there is a small jumper wire in the other 2 spots. I have found lots of info on adding the ignition map switch but i can't find anything about this connector or if it was factory. There is a small coil of wire just before the connector and the connectors appearance makes me think it was some aftermarket or home brew ignition map switch. This is a carb US 450sxf.
    • By riyaadhd
      hi TT users
      i have a flat 11 acre property 20 mins from my house. the property has a pond in the middle of it.
      i am wanting to build an mx track on there, What equipment/excavators will i need to hire. how will i go about constructing the berms, whoops, table tops and jumps. And how can i keep out unwanted riders. How much dirt will i need?
      i would be great if any ones knows track designers and cheap dirt and machine hires. (Dont have much $$ to spend so free or cheap dirt and equipment would be GREAT )
      i am in Brisbane, qld, Australia. Any quarries i can phone to dump free dirt
