kx100 top end rebuild help
hey was looking at purchasing
Wiseco Top End/Piston Rebuild Kit for my kx100 but there has three to choose from
52.5mm
53mm
54.5mm
what is the difference and which will fit my stock kx100 top end ?
That number refers to the bore of the cylinder. 52.5 is stock, the others won't fit.
Measure it (the cylinder) before you order a piston unless you are 100% sure it is stock.
Those are pistons for bigger bore cylinders for the 100,as stated above 52.5 is the stock bore.
If you purchased the bike new, and this is the first rebuild, you should be fine with a stock sized piston. If the bike has seized, or has had the top end rebuilt before, make sure you have the cylinder checked and measured by machine shop before ordering piston.. Good Luck
52.5mm
53mm
54.5mm
what is the difference...
exactly 0.5 an 1.5mm :busted:
i like namuriu
i like namuriu
I think you mean Namura. BTW, they are the cheapest cast piston you can get. they are a cheap budget replacement. Usually what some shops will use for a cheap rebuild. I only stocked & sold Vertex or Wiseco unless someone was dead set on buying cheap.
Even though Vertex is a cast piston, there's about a $25 difference in my cost between the Namura and Vertex. Wiseco was about $10-15 above Vertex.
I don't think Namura has a piston for a KX 100, had good luck with them in the 85's though.
just put a namura piston and ring in my kx100 and it rips
the use of a cheap piston wont be noticed by the bike, performance wise, untill it fails
go see his other posts
What exactly is it that makes the Namura "cheap" is it the coating or the hard anodized crown?
the fact that it is cast as opposed to being forged
Probably been through 25 pistons in the 85's and 100's and have had far less failures with the cheap ones. Namura's catalog still doesn't show KX 100 piston for our years.
KX100
The wiseco's I run now only because there's nothing else in a 54.50 bore.
1995-2009,2011
NX-20010
NX-20010R
NX-20010T
NX-20010F
COMING SOON
COMING SOON
52.5
ebay buddy
2005 Kawasaki KX 100. When you put the cylinder and head back on is there a certain torque pattern if so what is it and what is the FT LBS of torque for each( Cylinder and Head) ?
Thanks,
i dident do any sertin order order beside the same way u do a tire and untill the bolts are tight
dude, seriously, you need to stop giving information(or attempting to anyway). your posts should be in the form of a question only.
OP- criss cross, 18lbft
Thanks
