Okay so i just bought a 2006 KX250F for a motor cycle shop. I started riding the bike and the backfire wasnt bad when it was warming up but after it was warmed up in iddle it still had backfire. and when i ride it easy it has backfire to it too. so i took it to the shop i bought it from said there was nothing wrong and it so post to do it. So is that true because i thought there wasnt so post to be any backfire unless you get in the high rpms.
Wow have you came to the right place for good information! Use the search function up top to search this forum for "Lean" or maybe "backfire". You will find plenty of discussions on the topic. It is probably needs the fuel screw adjusted, or larger pilot jet (42 is very common), or hot start is not fully seated, or has an air leak. Good luck and welcome.
  • Similar Content
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
    • By MotocrossMaverick
      Hey guys i have just gotten off my Honda crf150r and i am looking for a new bike. I have been to the dealership and have already checked out the Kx250f and the Crf250r. I am looking more at the Rm-z250 then any other bike right now. I need help finding what bike would be best for me. I have never been on a 250 but i am starting racing about a month after getting the bike. I was also offered $5800 for the Kx250f and i know it killed 2012 i am just not sure about a Kawasaki. Honestly i am not sure bout any please help!!
