Oil seal replacement 1985 CR250
Which way do the seals need to be installed?
I don't have the Honda service manual and I don't know if I trust how the old seals were installed. The Clymer is just that, a Clymer, so the pictures aren't great. Online depictions (MotoSPORT) appear to show the flush side facing outboard.
All the seals go flat side out. If you mean the crank seals, they go in until flush with the case.
Great information. Thanks for adding the part about the crank seals.
No problem, I just put one of those together myself.
