03 125 gearing for MX
Started to ride MX on my 125, what gearing is recommended for it? Im having trouble getting "up to speed" to clear larger jumps and im getting the R's up plenty so Im guessing its gearing more than it is me. What are you guys running?
Your 2003, I think, has a 13/51, and I can't find any larger rears for sale, so you'll have to drop the front one tooth.
If that's too much low-end, then you'll have to get a slightly smaller rear...
47/12 = 3.92 (stock ratio with different sprockets)
51/13 = 3.92 (stock)
48/12 = 4.00
49/12 = 4.08
50/12 = 4.17
51/12 = 4.25 (may be too much for MX)
You'll notice going down 1 on the front is about equal to going up 4 on the rear, and vice versa.
Edited by ridleyredraider
Im running 52/12..
Hah, wow...then it's not the gearing. Maybe your clutch plates are slipping.
Also depends on whats done to the bike. Still stock? We run the stock gearing and it does pretty good on short & open tracks.
But I'll have to repeat this again, The FMF pipe on his bike made a huge improvement on this bike. We did add Vforce reeds but that only helped a little with throttle responsiveness.
But based on what type of tracks you ride. A closed in, tight SX style track or wide open. Last weekend my son rode a newly designed SX style track on the 250 and the gearing really sucked but it was all in fun so he was just out to ride.
Here's a vid of him on his 125 in that back yard. It's a tight track. But as for the open tracks, he has 6 gears.
Dylan & Kody
Im getting power, its got a FMF and jetted perfectly, zero bog. I know I need a rear tire, but that should not make or break me clearing stuff. The jumps at my local track are much much bigger than that video ^^ with about the same take off area.
A worn tire is part of the problem. You're not gonna do much with less than 75% tread without have traction issues. Alot of our tracks are like you're describing aswell.
1. It's a 125
2. it's gonna take practice sweeping turns faster and staying on the pipe.
3. May want to have 2 or 3 different front sprockets for different tracks.
  • Similar Content
    • By luke8500
      Hi all,
      I have a 2004 Kawasaki kx250 that died suddenly on me the other day. all i can get it to do is backfire every once in awhile. Tested the resistance and everything of the magneto and stator with a multi-meter and all is good.  Coil is new oem Kawasaki the reeds are brand new vforce and the top end and carb have been completely rebuilt.  key on crank is intact and all the timing marks are lined up. I hooked a timing light to it and spun the motor over really fast and found that it is sparking way to late.  The service manual says that it is supposed to fire 14 degrees before TDC but it is sparking way after TDC.  Im thinking its a fried CDI box since its the only thing i wasnt able to check.  Any help would be appreciated
    • By luke8500
      Hi all,
      I have a 2004 kx 250 2 stroke and it wont start.  it only backfires.  I was out riding it one day and came up to a stop so the bike was just idling and it started to try and die so i revved it up a few times then let it die and now it wont start back up.  It only pops or backfires when you kick it.  Its getting good spark and i just put a brand new plug and coil in it. I took the reeds apart and they look like they're brand new.  It was running great before so i dont know what happened.  Im thinking it could be a fuel problem even tho the plug is a little wet if you take it out after a bunch of kicking.  Any help would be greatly appreciated
    • By Zach121
      Alright, found three bikes all located where i live in Texas. I know they're all very different, but if you could tell me what you think each bike is worth, and which one would be the best deal. Thanks.
      Notes: Both 2 strokes have new top ends. I think the front brake lever is broken on the kawasaki.
      KX250 2002 $800-$1000?
      YZ125 2000 $1250
      KTM 400SX 2002 $1200
    • By Ryan Turner
      So I'm at a bit of a cross roads, I currently own a 06 rm250 and I love it. I also have a 02 kx250 which I'm selling with intent to buy a newer two stroke. I can't afford a newer ktm and the older ones aren't that great and kawasaki never impressed me. so I'm stuck between 06 yz250 and 05 cr250. I've heard the yz and rm after 06 are almost the same bike just the Suzuki handles better and the Yamaha has better suspension. So I'm not sure if I wanna buy carbon copy of my bike with slight differences. That's why I'm interested in a cr250 I heard the 02+ models RC valves are shit garbage but was mostly fixed in the 05-07 models. I ride at a track and at some bogs down the road from me. So from people who have owned both, what would you recommend. I know the cr is known for a hard hitting power band which I enjoy since im an aggressive rider. Should i just see which deal comes my way first.
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
