200x
Hey all Im building a parts list for my 120 build and wondering what year 200x to pull a carb from?If I get one off ebay is there a part number I should be looking for?
Thanks Ben
1983, 1984, and 1985 atc 200x carburetor is what you want. 1986 and up are different and not suitable.
You need a 1983-1985 ATC 200X carb, with PD on the side and model 62B for a #. You can use the stock 100 cable if you are using the stock 100 throttle. You also can use a CR80/85 throttle cable if you use the CR80/85 throttle. Some guys use this throttle for faster acceleration.
