oil level
On the twin chamber forks, when adjusting oil level for tuning are talking inner or outer chamber?
Level adjustments via outer chamber. If you go heavier or lighter springs and or fluid. You have to be aware of the levels. If you run a heavier spring or oil weight, you will have to go lower on the levels and vice versa!
Hope this helps!:busted:
james
