New plastics!
I got an Acerbis silver award card for 40% off. So, I am going to get new plasitics for my bike (02 yz250). The kit doesn't come with the front number plate or fork guards. They said the front fender and the side panels have changed in 06. Will the 06 side panels bolt up to my bike? I sorta like the look of the newer front fender that is why I am asking.
and what year is your bike?
02 yz250
Anyone know? They both have the same sub frame and frame geometry, so everything from 06 should bolt up to my 02, right??
Yep side plates will fit.
All the plastics from 02+ are interchangable on the 2 strokes! Since the kit doesnt come with a front fender, grap up a 10-11 450 fender.
The kit does come with the front fender. It doesn't come with the front number plate. Maybe I can order all the parts separate. Do you think my bike would look good with the 2011 450 front fender? Also, does anyone know if the side panels look any different from pre 06 to 06?
Sorry I misread about the fender/ # plate... but yes the 450 fender and #plate makes any Yz look great! Gives it just enough of the current look. I have one on my 96 Yz and it gives it a current look for sure. Really cleans up the lines. Looks better than my 08 for sure.
Old fender and plate
New fender and plate
Just to give you an idea of what it will look like compared to the normal round Yz fender (I know my old one is a little different but it is still pretty similar to what you have). I think the old fender looks pretty silly in comparisonson when you can update for the same price.
I dont believe there is any difference in the side plates look wise.
The right side panel on the '05 and newer YZ has a slightly different curvature to it. It should fit your '02 with no difficulties, however.
Also, I remember the front numberplate mounting tabs mounting up a little differently on the bottom triple clamp... they went from a male/female slip fit to a female/male or something like that.... it may have been pre- '02 however. Pay close attention to that on your numberplate if you get an '06 plate.
Yep, front plate is slightly different but you can mount it up easily with some plastic spacers/different screws if i remember right. It will look sweet on your 02' It was not hard to figure out. Someone has covered it on here before. Good LucK!
Thanks for all of your help!
No problem... if you go to the 06+ or 11 F fender and plate check out the sticky at the top of the 2 stroke forum. It gives a step by step with pics on how to mount them up and its really easy.
  • Similar Content
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
    • By Randomneewb
      Hey guys, I have a 2003 cr125 I bought a couple weeks ago and I'm having a problem with it. The spark plugs die every about 15 minutes, with hotter plugs it will last about 45 minutes. I herd that if the timing is off it can over heat the plugs and burn out the the resistor. Is there any truth to that? The reason I thinks it's not fouling is because when the plug dies it gives no spark no matter how much you clean it, And it shorts out.
