42 pilot jet in a 2000 DRZ 400E?
I think stock is 48, but I've had real good results with a 42 on my KTM 400. Just wondering if anyone recommends this size pilot for the DRZ. Better throttle response? Thanks -Paul
Throttle response is managed by the AP.
Pilot jet is for idle only. You select the best pilot jet and set the fuel screw for a perfect hot engine idle.
Fuel Screw/Pilot Jet
Fuel screw settings in the 'book' are recommended starting points. Every bike is different, as is the temp and altitude. Set the screw according to this method. Do it with the bike fully heated up.
Gently turn the screw all the way in. Now back it out two turns. Start the bike and fully warm it up, go for a 10 minute ride. Set the idle to speed to 1,500~1,800 RPM as best you can (I know, without a tach this is tough, just set it to were it idles relatively smoothly). Once warmed, slow the idle to the lowest possible speed.
*** When turning the fuel screw, keep an accurate 'count' of the amount you are turning it and record it in case you have to reset it for some reason. Makes life easier when you can just set it from notes Vs. going through the procedure again.***
Turn the screw in until the idle becomes rough or the bike stalls.
if it stalled, open the screw about 1/4 more turn. Restart it and slowly screw it in till you can just perceive a change.
If the screw can be turned all the way in and the bike still idles perfectly and does not stall, then you need to go down a size in pilot jet.
Now very slowly, open the fuel screw till the idle is smooth. Blip the throttle, let the bike return to an idle, wait say ten seconds. Confirm it is the same smooth idle.
If the screw has to be opened more than 3 turns to get a smooth idle, you need to go up a size in pilot jet.
If you find it does not stall with the larger jet but has to be open more than three turns with the smaller pilot jet, put the larger one in and set the fuel screw at 1/2 turn.
If the idle speed increased, adjust the idle speed knob to return the bike to a real slow idle speed. You must then re-visit the fuel screw. Keep doing this till the fuel screw is opened just enough to provide a nice steady idle at the lowest possible RPM. Once this is done, increase the idle speed to the normal one for your bike, typically about 1,800 rpm, but go by the spec in your manual.
Wiliam, thanks for the detailed instructions. I was looking at the carburetor today and cannot see how the fuel screw can be turned with the carburetor on the bike. There is absolutely no room to get any kind of a tool in there between the carb and the starter. It would seem a dedicated external fuel screw is required. What do you recommend?
This is why people buy the extended fuel screws. Do not get the commonly found alloy ones. Get a brass or stainless.
Kientech
Kouba
James Dean
Scotts
R&D
There are some others.
There are also special tools that can be used but unless you are a pro mechanic, they are too expensive for regular Joes.
