1983 xr350r rear tire
I'm looking for a 4.60x17 inexpensive rear tire for the xr350r . It seems to be hard to find a tire in that size for the old pig. Anybody know of one. It has a cheng shin c-755 on it now but when I look it up they dont offer a 17inch tire anymore.
I ended up having to go with a 130/90 tire. The only issue is the plastic chain guard. I ended up taking it off as it was starting to wear the plastic away in a little triangle area. If you find a decent stock sized tire, I wouldn't mind knowing for future reference, however this new tire size does me well, especially since the majority of the riding I do is sandy. Good luck!
Google cheng shin c755 tires 17"
Lottsa 'out of stock' but found these Cheng Shin tires:
americanmototire.com 5.30-17 - $58
traxms.com 460-17 - $39.00
traxms.com 530-17 - $56.00
keep lookin :busted:
edit to add:
If you're not hung up on Cheng Shin, there are others easier to find:
rockymountainatvmc.com 5.10x17 IRC VE33 - $60
Kenda K270
but why do you NEED the old inch size?
what difference does it make if the actual size fits?
I ended up having to go with a 130/90 tire. ...plastic chain guard. I ended up taking it off ...
no wonder,
your 130/90 actually is wider than a 5.10
well a 130 is 130mm wide, a 5.10 126mm
120/90 about equals a 4.60
120mm vs 116mm
