Motor for 2006 yz250f
I have an 06 and Im thinking about picking up a back up motor. Im wondering if the 09 would fit? Im thinking 09 would.........not sure if anything beyone 09 would. Just curious if anyone knew before I do research.
Is that just at the cylinder or the does this cause issues with the airbox or subframe.
It's just how the manifold mounts to the cylinder, the carb is the same. Also note that you need to know what year the engine is b/c the head changed between 04 and 05, and as a result the shape of the piston dome changed to match it. If you run a newer piston with an older head you can have some big problems.
