RMZ 450 top end question
Is it possible to take a RMZ 450 cylinder, piston, and head and swap them onto a drz 400 case? I know there might be some issues to over come but would it be possible? If not has anyone swapped in a RMX 450 engine into a DRZ frame?
Thanks,
Casey
as to weather or not it is possible... anything is possible with enough fabrication. currently i have a honda 25cc head and piston running in a brigs and stratton 150cc bottom end for a super millage vehicle project. just about every single part on the motor has custom machine work done on it. so yes im sure it is possible. as to weather it is worth it well im not sure exactly what modification would need to go into it so i cant help you there. hopefully someone has more experience with those 2 engines and can give you better insight on that.
Why would you want to do that? Go to the DRZ forum and you will find out that the DRZ motor can be made to haul ass without all that custom work!
