Hinson clutch conversion to 6 spring 09-12
Trying to figure out if I need just the inner hub and pressure plate to convert the 4 spring clutch to a hinson 6 spring.
Can I use the stock basket, 08 springs, OEM clutch plates/fibers and buy only in the inner hub and pressure plate?
Thanks.
Oh, and anyone use the 6 spring Wiesco?
You can use the OEM clutch plates, fibers, and basket. You'll want 8 full fibers and 7 plates like on the '09 not the jutter spring setup that came on the newer ones (not sure when honda switched, '11-'12 maybe). I believe the inner hub/pressure plate kit available from hinson includes springs but not positive.
There's also the new Single Spring setup to consider which is pretty cool. Just installed mine tonight.
Didn't know this....."08" and previous baskets don"t fit "09" and newer. Different spline size. If it wasn't for that, there are much cheaper ways to install a six spring clutch on an "09" and newer CRF 450. There is a guy on Ebay sells a six spring setup much cheaper than H-guys.
