jetting question
hey yall, just got a 2011 drz-s and i'm x-eyed now from all the info here, but my question is this...all stock if i do the 3x3 mod i should jet it 155 main, jd needle (blue) on the 4th clip, 25 pilot w/stk fuel screw, 2.5-2.75 turns out correct? and the jd jet kit is #jds005 correct? im in vegas and elevation is approx. 2000 ft.
You have researched well.....:busted:
#jds005 is the correct kit....http://shop.thumpertalk.com/product_p/int_jdjetting_jetkit.htm
for stock pipe , 3x3 mod ...
155 main jet
jd blue needle
clip 4
22.5 pilot jet with extended screw or 25 pilot jet with stock screw
2.75 turns
If your regularly going above your current altitude try clip 3...
id keep it in the 3rd clip and try that....removing the needle is easy enough to change postions with out removing the carb.....
Your in Vegas, weres the bike pictures?
155 main jet
jd blue needle
clip 3rd clip is the best!
22.5 pilot jet with extended screw, 2.75 turns out.
The bike run fat here, we don't have the good sea leave Cal air here. You can even go with a 152.5 it will run a littel better. I would sick with the 155 just in case you do go lower in altitude.
