WP 5018 PDS shock
does anyone know where I can buy a rebuild kit for this shock?? things like seals bushes, rubber bumper if needed I have around 85 hrs on the shock and its never been rebuilt
I don't think they sell a kit as such ,would not hurt to replace the bump rubber ,seal and piston ring and o ring behind the piston ring , have you done one before ? they are a pain to service !
You can find all the parts in 1 place
www.mx-tech.com
The OEM bump stop is real expensive and breaks down fairly quickly, MX-Tech has a better one and it costs less than the OEM bump stop.
mog ive never touched the shock, and something else I was also going to ask you was while I have the shock apart I was thinking of getting a slight valving changed I want it plusher on high speed hits and bumps and ive heard dwight rudder say that these shocks have to much high speed valving and get 30% of it removed what do you think
what bike and year, your weight and speed? i would never recommend a pds to service if you have not done many shocks before, they need a few special tools and are a real pain to bleed, i would pay someone to do it unless you plan to do one a week(ie thats how many you need to do , to make it worthwhile to invest in the kit needed)
yeah I have heard they can be hard to bleed etc. Im defiantly getting my local ktm dealer to get it done. 09 250sxf, im 75KG intermediate MX and expert cross country.
yes you could remove some high speed , it would help in the rough
any ideas how I could explain this in the best possible way to my tuner is it really just as easy as saying " I want this % of high speed valving removed " what else would need to be done would the rebound or low speed need to be touched
Honestly I don’t find that servicing the KTM shock to be that difficult. Probably the hardest thing is to install a sharader valve. There is some debate that a bleeder is required for the shock but I find that if you take your time when pouring in the oil and closing it up a bleeder is not necessary. In the worse cases, I sometimes let the shock sit overnight before closing it up just to ensure the bubbles are out. If you lived locally I would invite you over and service your shock for you.
In my experience these shocks should have the oil changed out roughly every 30 hours if you ride MX and I am guessing about 50-60 hours for off road. I ride a lot of MX and at 30 hours I find myself to start to turn in the compression clickers to compensate for the failing oil.
I don’t see why you could not ask a tuner to reduce the high speed compression by a percentage rather then remove this shim or that one. At least that way he can adjust the shim stack based on your impute to get you what you want.
if I was taking it to a tuner I would explain what I want and let him
work his stuff , you don't go to your doctor and tell him
your diagnosis , you tell him your symptoms and let him choose the best route of action , the PDS is hard to get parts for ( funny shims on later ones) ,harder to improve , hard to bleed, harder to set the n2 piston than a bladder and harder to gas , apart from
that its a doddle ;-)
