Need help with ratio"s
Hey ive built a go kart using a 2000 Yamaha ttr-125 engine an i want to use a jack-shaft for better placement on the frame an to gain some speed. I was wondering could i use the original 13 tooth to a 28 tooth on jack-shaft than the secondary jack-shaft sprocket being a 10 going to the axle a 28 tooth? :busted::bonk::lol::busted:
Edited by Jsmith-ttr125
I dont want it in the health an fitness area
I built a cart with a YZ 125 motor on it and that was the toughest thing to do, get the gear ratios right to get more top speed.
When I first got it done and tested it out, it had a lot of snap but no top speed at all. I tried going to the biggest front sprocket and the smallest rear sprocket I could and even tried having custom sprockets made!
After all of that and going back and forth, to get the top speed I needed I had to change the gearbox internally, I used the gearbox off a "cart" 125 motor.
Good luck and have fun, I know riding mine is a blast!
All the best,
Jason
