2006 KLX300R Swingarm install
Just finished up a bunch of maintenance on the bike and I'm having a real hard time getting the swingarm back on. I've squeezed the seals on as best as I can but it still doesn't want to slide into the frame. Do I need to just keep playing with it, or is there some trick or something I'm missing?
Also, does anyone have the torque spec for the front sprocket?
Thanks
Correct bearings yes.
Should I be trying to mount the swingarm with the linkage attached to it, or try to mount it and then bolt up the linkage? Or does it matter?
Finally got it on, had to file down an edge on the case where it mounts to, everything seems in order now.
Still need the torque spec for the front sprocket if anyone has it.
