Difficult to kick start while in gear
Is this normal? I have the clutch lever adjusted per the manual. It will start way easier in neutral, but when I try to start in gear with the clutch disengaged, it will not start.
Edited by bambooi
That is normal. There is drag from the clutch plates.
When the oil is fully warm and bike is up on a stand, put it in any gear, pull the clutch in fully and turn the rear wheel. The drag from a normal clutch should feel about double the drag you'd feel in neutral if you have an o-ring chain.
If you still think the drag is excessive, then pull the plates out and inspect everything.
