how to get this off my cylinder?
It looks like a previous owner has tried to clear coat the cylinder and it burnt. Ive used a wire wheel to get as much off as I could but It wont fit in the corners. Is there anything i can spray on it to take this stuff off? or any other ideas? As you can see its in all the tight areas.
if none of those have worked and you have access to a tig welder make some passes over it on ac and low amperage with a lot of electrode positive bias. then it should just come off by wiping it with a rag. if you cant do that try lightly heating it with a torch and the same thing should happen.
