Cylinder salvage?
Can a cylinder and cases with screwdriver marks be refurbished any way or salvaged and repaired to where I don't have to use gasket sealer to keep it from leaking? I was thinking of having bothsurfaces machined down and then put a spacer in there, i was told no thats not an option by pro circuit.
-James.
Sounds feasible to me, as long as your deck heights, and squish remain the same, just eb careful of any dowels and studs for fiment.
For all the trouble you'd have to go through to get your solution to work right, and for all the potential problems you'd incur along the way, I'd suggest that finding a set of clean cases off EBay would be easier and cheaper. I had the same problem with a CR250R, and bought a clean set of cases for $150 two years ago.
