03 250SX powervalve governor
2003 250 SX: I recently found some small needle bearings stuck to my drain plug. I pulled motor down / split cases to clean it out. Found out the needle bearing inside the PV governor died. KTM wants around $150 for the entire governor assembly.
Since I am a cheapskate AND the thrust washers and bearing surfaces were OK, I found a replacement thrust bearing at QBC Bearings, part number BTHBNGMAXK1226. Cost is about $4 + shipping. :lol: You have to order at least $10 of parts, so make it worth you while.
Hope this helps.
