Oil coming out oil breather
I have a 2005 crf 450. The last couple of rides I notice a small amount of oil on the swing arm. I finally tracked it down to the oil breather that goes into the air box. This breather connects to the valve cover. What is causing this issue? I just changed my oil 700cc in the engine and 700cc in the trans.
check your oil levels to see how much your loosing from your trans, and double check your engine side isn't overfilled now. If it is, do a "search" for "oil migration" or "crank seal"..
The valves and piston have about 30hrs on it. Are you suggesting a bottom end rebuild?
