Stroker clearance issue ?
Question re the following setup
Hotrods 4mm stroker crank and Athena BB kit.
Does this setup require a cylinder spacer and/or clearancing of the piston ?
are you doing a performance upgrade Bill ?
No, I'm still using a relatively new CW BB kit and standard Hotrods crank. Happy with that.
I friend of mine installed the Athena BB kit and Hotrods 4mm crank on a very low hour DRZ of his.
It now has a lot of aluminum filings in the engine oil.
His next step is strip and inspect so I was just asking ahead for possible causes.
