Air box mod questions
Hey guys I wanted to delete my air box and run just a filter was thinking it will give me alot more air now my question is for jetting not sure what to run?main jet or pilot? I also know the filter will be vulnerable to water but I ride the bike in a parking lot doing wheelies and stunting so dosent see much dirt and water. Also with thos mod power wise would you notice a little mor snap from the motor? Everything is stock except for drilling out the fuel to air plug.
If I were you I would just cut the top of the air box. Run a 110 Main, 17.5 pilot, shim your needle a bit and start your fuel screw at 2 turns out. You will see considerable increase in power (or maybe you just think you have more power cause you can hear the engine sucking air??)
I have never been able to get one of these bikes to run well with just a pod filter.
If your stunting in a parking lot why do you need more power? I always loved stunting an F4i cause the throttle was so mushy, much more forgiving than my 900...
Edited by levic900rr
If I do a seat stander and jump to spreader and drop from balance point I dont have the power to bring it back up im talking doing it in 4th so its week up there. So when I cut the top off I really just cut the whole top of the air box off? Leave
door or remove as well?
You will see a channel in the mold of the top of the air box, it almost looks like a knock out. Use a razor knife and cut along that line. The hole will end up being about 4" X 3" and throw the snorkle out.
As for your stander to spreader...
You need a hand rear brake. That way you can rock the thing way over backwards before the transition.
Yeah I have a handbrake im also on the stuntride and and stuntlife fourms ive stunted fda lot of things just trying to set this little guy up.i really want to make a 12 bar just not sure how to mount it to the back of the bike
My buddy Patrick Stephens had a 12 bar on his TTR, he also made this crazy circle thing that made it so he could roll an endo, then flip the bike over frontwards and it would roll all the way over back onto the wheels...
There is a shot of him doing it about halfway down this page
http://www.patrickstephensfreestyle.com/
