Remap for Mod's??
On a 2011 if I replace cams with a stage2 and add a high compression piston will I need to do anything with remapping for the fuel..if so, how and what?? Or will it adj itself as needed??
I have good news and bad news. The good: you can tune it to exactly the air/fuel ratio you want and rip it in any rmp range!! - !!
The bad: you gotta install an aftermarket computer, oxygen sensor, bung, and data unit.
ANY generic map you install after tinkering under the hood is 100% pure speculation. The ONLY way to get a map loaded that is tuned to your jug/head/exhaust is a laptop computer in one hand and the throttle in the other.
Hmm..So is that program sold though kawie?? Or what aftermarket?? Will the bike run worse then stock after doing mods without changing the mapping?? What about generic ?/ Can you buy them pre set up for your mods the you do??
