2012 for Offroad
Anybody running the 2012 kx450s offroad yet? Like for desert or GPs? What kinda mods are you running and how do you like it?
I have a new '11 set-up for off-road. It's not all that different from the '12, at least in terms of what's needed for off-road.
- Suspension (revalved/sprung). The stock suspension is a bit scary off-road, at speed.
- O-ring chain
- 14/48 for high-speed stuff. 14/50 for tighter stuff like GPs, motocross
- BRP chain guide (must have!)
- Be ready to change the stock chain slide soon (get a TM Designworks if you want one to last)
- IMS 2.7 gallon tank (you hardly notice it!)
- IMS pro series footpegs (stock ones are weak)
- Acerbis skid plate
- Hinson clutch cover
- GPR stabilizer (Scott's will do)
- Burn up the stock tires and switch to the 603/604 (harder compound). I still like a 110 on the rear though and I'd switch to a 80 front tire. Not sure why they come with a 90.
- Bridgestone heavy-duty tubes
- Hand guards (I run the Acerbis Uniko)
- I'm running the new FMF 4.1 RCT w/ Megabomb header, but for high-speed stuff, I'd recommend the Powerbomb for more mid to top
- I have a remapped ECU from Kawaski off-road. It mellows the bottom, changes the advance a bit and has more mid to top. The power delivery is very linear, but I like having the bottom mellowed out a bit for single-track. It's a little lean and I have to run a 50/50 mixture of race gas & pump gas, otherwise it can detonate under a heavy load.
My KX450 is the best bike I've ever owned. Even after setting it up for off-road, I don't notice much of a difference. The weight difference isn't that much. The larger tank is incredibly slim. It's such an awesome all-around bike. I don't change a thing except gearing when I go to the track or ride tight single-track.
