Oxygen regulator, nitrogen tank. Will it work???
Can you use a oxygen regulator on nitrogen tank. I have two regulators for oxygen and a nitrogen tank. The oxygen regulators thread will screw into the nitrogen tank
yes....
If you do that and there are any traces of oil in the nitrogen tank or any part of the nitrogen system, then you will be flirting with disaster if you ever go back to using it with the oxygen tanks. I know this from SCUBA diving. The oxygen regulators use a special grade of oxygen safe silicon inside. This might be different with the systems you are talking about but you shoulod be aware that there is a difference.
