need help about 96 geo tracker
just put a new radiator on my 96 geo tracker when i started it water blew from the radiator its building up way to much pressure. when u loosen the cap u can hear it whistle what could be wrong
Air pocket in system, turning to stem and boiling over. Let it cool, add water till its full. Check back, add more till the system wont accept any more than you are safe to run it.
Also, turn the heater on full HOT and that will help "burp" the block.
Look for a bleeder screw on the thermostat housing, upper hose or outlet.
